Radio
Old May 15, 2006 | 12:15 PM
jjohnston12385's Avatar
jjohnston12385
Radio
Hey guys. Friend of mine just picked up a 2005 Explorer XLT. He has an Alpine radio from his old car that he wants to put in it, but we can't figure out how to get the factory radio out. It doesn't have the usual FORD keyholes on it, and that silver bezel trim around the radio, we can't figure out how that comes off either. Any help would be greatly appreciated.
Old May 17, 2006 | 10:04 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
I can't get the picture to post but if you give me a fax number i'll send you a copy.
Ed
Item Part Number Description
1 7804302 Center instrument panel finish panel
2 W705314 Audio unit screws (2 required)
3 18C868 Audio unit
4 14401 Audio unit electrical connectors and the antenna lead-in cable
Removal and Installation
NOTE: Make sure the ignition switch is in the off position.
Remove the center instrument panel finish panel.
Remove the 2 screws and the audio unit.
Disconnect the audio unit electrical connectors and the antenna lead-in cable.
To install, tighten to 2 Nm (18 lb-in).
To install, reverse the removal procedure.
Old May 22, 2006 | 02:39 PM
Exploder02's Avatar
Exploder02
IF it's like my '02, that finish bezel pops off, and you'll readily see the 2 screws to remove the radio. That bezel is on VERY tight, I fashioned a removal tool for it by bending a spackling knife and covering it w/ tape. It seems like it's gonna break while you're pulling it off, but at the last moment, it pops loose!
Fisherman46
2004 - 2008 F150
Feb 17, 2015 06:53 PM
David F.
May 4, 2014 09:24 AM
jkothe65
May 20, 2007 10:11 PM
swinehart07
Aug 26, 2005 06:19 AM
droFnaF
Aug 26, 2001 08:44 AM
