Coolant
Old May 14, 2006 | 10:52 PM
dougwood62's Avatar
dougwood62
Coolant
I recently changed the waterpump on my 99 F350 with the 7.3 and I would like to know how much coolant it can hold? Also my water pump is leaking because I don't think it is sitting on the gasket right. Do you have any ideas that will help it go on right so I dont have to take it off again?
thanks
Old May 14, 2006 | 10:55 PM
Kajtek1's Avatar
Kajtek1
Don't know the official data, but I just changed my coolant to lifetime one (blue stuff) changing the thermostat to 203 and adding filter on its way.
After draining from the radiator plug and it took approximately 5-6 gallons.
Old May 15, 2006 | 12:33 AM
aklim's Avatar
aklim
Clean the mating surfaces well, put some sealant and torque the bolts down tight? Do check the flatness of the mating surface with a flat edge
