Sponsored by: Innova
Stock system louder, how
Old May 14, 2006 | 10:48 PM
ktplotts's Avatar
ktplotts
I got an 05 F-350 and the stereo in it is ok unless i have the windows down, then it just isn't loud enough. Is there a way, besides replacing the speakers to make it louder? I really can hardly hear over the wind, diesel engine, and tubo wistle.
Old May 14, 2006 | 11:04 PM
furball69's Avatar
furball69
A 4 channel amp is about the only way to make your system louder, and with a higher powered amp, you'll likely have to upgrade your speakers as well. You should be able to get a decent amp and 4 speakers for between $300.00 - $400.00. There may be some type of harness that will allow you to connect to the factory speaker outputs out to the amp speaker level inputs and not have to cut into your factory harness... not sure about that though.
