Help...Will not start !!!
Old May 14, 2006 | 05:11 PM
SteveB123's Avatar
SteveB123
Exclamation Help...Will not start !!!
We have a 2001 F250 7.3 turbo desiel that ran beautiful until this morning. Cranks great but will not fire up. It was running fine when we parked it yesterday. We tried every couple hours but she is "no go". Any comments would be greatly appreciated.
Thanks,
Steve
Old May 14, 2006 | 05:33 PM
magnum300's Avatar
magnum300
does the tach move while cranking? if it does not it is probably the cps
Old May 14, 2006 | 05:41 PM
CAT_man_963's Avatar
CAT_man_963
Any smoke out the tailpipe when cranking?? If "no smoke" - then I'd agree with Magnum on the CPS. Otherwise I'd be thinking to check the Glow Plug relay...
Old May 14, 2006 | 05:57 PM
Grunt0311's Avatar
Grunt0311
I just had the same problem with my truck. It would crank, and blow lots of white smoke out of the tailpipe. I changed the GPR (glow plug relay), about $20 at NAPA, and it started fine this morning. Where are you located, are the mornings chilly?
Hope this helps
Bill
Old May 14, 2006 | 05:58 PM
magnum300's Avatar
magnum300
It would help us a lot if you filled out your signature
