Sponsored by: Auxito
Triton V8
Old May 14, 2006 | 04:26 AM
damoperator's Avatar
damoperator
Triton V8
What makes the designation Triton different from any other 4.6 or 5.4L engine?
Old May 14, 2006 | 05:52 AM
peter88's Avatar
peter88
I am new here, but is it 3 valves per cylinder ?
Old May 14, 2006 | 10:11 AM
captain p4's Avatar
captain p4
I believe the triton are the 5.4 and 6.8 truck series motors. (do they call the 4.6 a triton in the truck??) ANyway, they are the same engines, no difference at all, just a name.
Old May 14, 2006 | 11:23 AM
mfraley65's Avatar
mfraley65
The 4.6l is called a triton also.
Old May 14, 2006 | 12:00 PM
screwy's Avatar
screwy
Marketing, makes it sound spiffy.
P.s. The 3 valves dident come along till 2004.
Old May 14, 2006 | 12:07 PM
LxMan1's Avatar
LxMan1
Kinda like GM's Vortec and Dodge's Magnum. We have a Triton!!
Old May 14, 2006 | 11:41 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yes, the 4.6 is also a Triton. It says so on the throttle body cover on my '97 4.6L
Old May 15, 2006 | 08:50 AM
deltasoft's Avatar
deltasoft
ehhhh just a name.....
Old May 15, 2006 | 01:42 PM
ddrumman2004's Avatar
ddrumman2004
Mine too. Yep...just a name.
Old May 15, 2006 | 02:04 PM
gui88ford's Avatar
gui88ford
name only.....needed smoethign because GM has vortec and dodge has magnum exc...
Old May 15, 2006 | 04:16 PM
KingRanchMan02's Avatar
KingRanchMan02
The name Triton came along with the first application of the Ford Modular V-8 engine. Just a marketing name as mentioned by others in this thread. Nothing new here. Manufacturers have been naming their engines for many years.
I have some knowledge of the AMC V-8 engines used from the mid sixties to the late seventies. These were called Typhon V-8s. I don't recall what Ford was calling the small block and big block V-8s in this era.
Old May 15, 2006 | 04:37 PM
deltasoft's Avatar
deltasoft
i think it was tomato juice lol v8
Old May 17, 2006 | 07:16 PM
damoperator
Thanks guys, this is my first truck above 1980. I'll be back and I am still reading alot.
Old May 18, 2006 | 12:48 PM
fbodyfan's Avatar
fbodyfan
They sure weren't callin em small - and big-blocks . That was a chevy thing
Old May 18, 2006 | 12:52 PM
blacklariot's Avatar
blacklariot
its not just a name!
Triton is not just another name... if you are overheating triton engines will cut out the four hottest cylinders and rotate through the coolest...it does this so that you are able to hobble to the nearest place you can stop...
