Eratic A/c
Old May 13, 2006 | 05:57 PM
panthony's Avatar
panthony
Cool Eratic A/c
my 01 supercrew having a problem with A/C going back and forth from cold to hot, and some days wont come off hot, yet the other day drove 2hours and got good cold air the whole time, pressure on low side is about 25 put entire 16 oz can of 134a in. any suggestions would help. also the heater would not adjust at all, strays hot. I also replaced the temp cont. switch.
Old May 13, 2006 | 07:26 PM
2000Ford2000's Avatar
2000Ford2000
If you are having both heat and A/C problems then you need to look at the blend door. It sounds like a vacuum problem.
jeffrey5679
May 8, 2013 09:29 AM
rslade76
2004 - 2008 F150
Jan 23, 2012 08:18 AM
Amexplus
2004 - 2008 F150
May 14, 2011 08:24 AM
ckeezer
1983 - 2012 Ranger & B-Series
Sep 21, 2008 10:25 PM
