Sponsored by: Auxito
Will not start
Old May 13, 2006 | 02:56 PM
4725larry's Avatar
4725larry
Will not start
I just bought a 1997 f150 xlt. I was putting a cd player. First, I disconnected the negative terminal on my battery to prevent any short circuits. I removed the old radio and saw that I would need a different mounting kit to make the cd player fit. I did not make any connections with the new cd player. I reconnected the radio and reconnected the battery terminal. When I turned the ignition nothing happened. The dash lit up and the radio came on. I tested the battery and it was at full charge. I checked the fuses and they seemed to be ok. When I turn the key there is no sound at all. No turnover...no clicking...nothing. Any ideas would be appreciated.
Thanks,
4725larry
Old May 14, 2006 | 01:04 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
Hopefully someone here will chime if shortly to give you the info that you need.
Old May 15, 2006 | 08:43 AM
deltasoft's Avatar
deltasoft
sounds like alarm is cutting your power.....do you have anytype of alarm?? perhaps also a cutoff switch you might have within the truck.... after your sure of those things then look around area you tampered with and see if you moved anycables around....
