Shackle/leaf spring advice
Old May 13, 2006 | 07:27 AM
oarhead61's Avatar
oarhead61
I have gone through most of the threads on this topic. Since the drivers side shackle is rotted my plan is to replace both. If I'm going that far I might as well either replace the leaf springs or have them re-arched (?) and add a leaf at the local spring shop. I don't want to raise or lower it. Just get it back to where it was. I'm sure someone has done this. What are the pro's/con's? I really hadn't planned on spending a fortune on this truck, but it is a truck and I'd like to be able to put more than a bag of kitty litter in the back......any thoughts?
Thanks in advance.
'91 F-150 regular cab
I6 - 5sp
Old May 13, 2006 | 08:25 AM
quicklook2's Avatar
quicklook2
just replace the shackles.
Old May 13, 2006 | 08:30 AM
oarhead61's Avatar
oarhead61
Forgot the hanger
I forgot to mention the hanger on that side is also shot.
Old May 13, 2006 | 06:03 PM
Ford4x4-JD70AB's Avatar
Ford4x4-JD70AB
I would just say replace all the spring bushings, bolts and shackle and put it backtogether again. Ill warn you, it doesnt look like a bad job but they can really be a pain in the butt. I had to use the torch on mine. (you'll need lots of beer to. lol) Make sure to use plenty of anti-seize when putting it back together. The springs are up to you though.
Old May 13, 2006 | 06:32 PM
quicklook2's Avatar
quicklook2
use a grinder.
this is a dirty, nasty job.
wear goggles, protect your skin from grinder burns, keep fire extinguisher handy.
do one side, drin some beer, do other side.
good luck.
