1978 - 1996 Big Bronco
Rear Springs
Old May 12, 2006 | 02:10 PM
78Jimmy's Avatar
78Jimmy
Rear Springs
I need to replace a couple of the leafs in the rear pack on my 79 Bronco, and wanted to know if anyone knew what the eye to center pin length was. The truck seems to be a little taller than stock, but I have nothing to messure it off of to compare it with.
thanks..
Old May 13, 2006 | 04:38 PM
Fordchic86's Avatar
Fordchic86
ignore post.
Old May 13, 2006 | 04:39 PM
MBBFord's Avatar
MBBFord
It should only have 5 springs in the pack, and the pin in the middle needs to be long!, b/c when you take out or add leafs you have to undo that bolt and the springs are no longer pressed together. If you get a add a leaf kit, it'll come with a long center bolt and tell you to cut off the extra after it is tightened up, but it isn't completly nessecary to cut the extra off(just for a cleaner look).
Old May 14, 2006 | 10:25 AM
78Jimmy's Avatar
78Jimmy
Thanks, but does anyone know the distance from the eye bolt on the main leaf, to the center bolt for the spring. Unfortunately, I'm not close enough to my truck, to messure this myself, but might have a good deal on 2 new sets of leafs.
Thanks
gthbryce
30
May 24, 2026 12:12 AM
Bigbruce
Apr 16, 2017 06:01 PM
664x4drvr
Nov 11, 2013 05:17 AM
streaksf
2004 - 2008 F150
Nov 29, 2012 03:34 PM
dillinewton
Offroad & 4x4
49
Mar 1, 2010 09:52 AM
