1966 - 1977 Early Broncos
351w Conversion
Old May 12, 2006 | 01:18 PM
72 Bronco's Avatar
72 Bronco
351w Conversion
Does anyone know wether or not a 351w MPI out of a 89' F150 will fit in a 72 Bronco? I know the MPI 302 will but i think the 351 MPI is taller and i dont know if it will fit.
Old May 13, 2006 | 01:17 AM
mauicruza's Avatar
mauicruza
Hello 72, This question has popped up several time before and someone mention at least 5-6" above the hood without a body lift. One member started a project like this but never reposted the pictures of the finished project. I'm curious also because I too have a 5.8 truck efi that I'd like to swap in some day. I've even considered an aftermarket car style intake like Edelbrock. They replied stating that their intake measures 11.5" which is still pretty tall. Someone also mention using one from a lightning but I don't know the specs on that.
I hope someone has pictures of completed swaps using the truck intake because I would like to retain good torque from the longer runners. Good luck.
Old May 13, 2006 | 06:16 AM
ken75ranger's Avatar
ken75ranger
The guys I know that have done this didn't use the truck intake. Either aftermarket or a Lightening lower intake with a gt40 upper.
Old May 13, 2006 | 11:41 PM
mauicruza's Avatar
mauicruza
Hey Ken, Do you know off hand if the aftermarket intake or GT40 still stuck up from the hood? If so, how much?. Thanks
Old May 14, 2006 | 06:41 AM
ken75ranger
Most of them had to go with a 1 inch body lift or a scoop or glass hood. One guy claims it fit but 3 others needed to work the hood. I think some of them were hitting the support built into the hood.PM me if need need more info I can send you to a great site for EFI in early Broncos.
Old May 17, 2006 | 03:55 AM
mauicruza's Avatar
mauicruza
Ken, does this site have info specifically on 5.8 efi swaps? thanks
