need help
Old May 12, 2006 | 07:11 AM
77F350's Avatar
77F350
Question need help
I have a 77 cs 460 motor I have replaced oil pump ywice oil sending unit and the heads pistons looked fine after 15 min warm up loses pressure and oil pump knocks
Old May 12, 2006 | 07:22 AM
holland501's Avatar
holland501
While you were replacing the oil pump, did you take a look at the rod and main bearings? Maybe take a Plasti-gauge reading?
Old May 12, 2006 | 08:34 AM
Mil1ion's Avatar
Mil1ion
Mod please remove this post.
Old May 12, 2006 | 08:37 AM
Mil1ion's Avatar
Mil1ion
Welcome to the site.
This is actually an engine only topic not a 73-79 truck topic.
FTE is huge and has engine forums for engine related topics.
Maybe a Moderator will move this to the 385 engine series forum for you?
Also, may I direct your attention to post #1 of this thread.
https://www.ford-trucks.com/forums/s...d.php?t=102632
Regarding the actual topic of Oil pressure (not in title of thread)...Your cam & crank bearings are worn out.
As the engine increases in temp the automatic action is for metal to expand.
This expansion (of the bearings) causes oil pressure to drop because there is more space between the bearings and the journals.
