floor pans
Old May 11, 2006 | 10:15 PM
inline6 Red Neck's Avatar
inline6 Red Neck
Red face floor pans
is there any tips on puting new floor pans and rocker pannels and cab coners to
what kind of tools will i need
Old May 12, 2006 | 06:20 AM
rusty90f1504x4's Avatar
rusty90f1504x4
ive cut mine out and in process of welding new floor pans in using sheet metal. could order new floor pans but the 4x8 sheet of metal was free. some people just pop rivot stuff on but i would recommend welding as it is a stronger solution. it would depend on how bad the floors are. in my case they were rotted extensively. as for tools a hammer, grinder with zip cut wheels vise grips and welder would all be helpfull.
cab corners and rockers can be cut to fit rotted areas.and welded back on
Old May 12, 2006 | 07:54 AM
FortyFords's Avatar
FortyFords
When doing this make sure you support(braces) the cab itself before cuting out the pan if replacing entire pan at one time.or the doors won't fit back in the openings.
Rich
Old May 12, 2006 | 08:14 AM
Greg 79 f150's Avatar
Greg 79 f150
all great replies, just adding here that should be a MIG welder purchased or borrowed for the thin sheet metal floor pan work, not a stick welder.
Old May 12, 2006 | 09:59 AM
rusty90f1504x4
also of note make sure when cutting the pan out dont cut too deep to cut the braces on the floor out or the cab mount.
Old May 12, 2006 | 03:21 PM
Rocket Racing's Avatar
Rocket Racing
Also consider an hand or air powered flanger, depending on where the rust is at. Makes for a nice repair if it can be used.
Old Jun 5, 2006 | 01:00 AM
460f250's Avatar
460f250
Anyone that's done this before have any tips on fitting the new pans? I've cut the old sections out, just the area your feet rest and part way up the slanted part under the pedals, and it seems the biggest challenge is getting the new panels to fit into the area that was cut out. I'm trying to get a tight fit so they can be welded in.
Thanks for any help.
Old Jun 5, 2006 | 01:21 AM
mississauga's Avatar
mississauga
A mig welder is a must, and with the gas kit is even better.If you are new to welding I would practice for a while on sraps first. The better the fit on panels the easier it is to weld. Make the pieces larger and keep grinding and checking until it is just right. It is a slow process so dont rush it. If you have gaps the welder will blow through and make tons more work in the end.
Old Jun 11, 2006 | 07:49 PM
Talltruck's Avatar
Talltruck
I had to make relief cuts to get the patch panels to fit in where the old panels were. Once I did that, I could push the panels in/out to get them just right. Then, I took my cutoff wheel and made cuts between the new and old metal, which left a perfect gap (about 1/8") to put a nice bead in with the mig. I did this in short sections, and it turned out sweet.
expguy121
Sep 22, 2012 06:57 AM
Indybeer
Nov 8, 2011 03:39 PM
ItsAFord55
Aug 2, 2011 03:24 PM
FordF100man
Apr 30, 2009 06:19 PM
