Sponsored by: Real Truck
Vibration
Old May 11, 2006 | 08:44 PM
nkfd110's Avatar
nkfd110
Vibration
I have a 2006 F 350 crew cab,4x4, v10,auto. At 45-50 mph there is a vibration.The dealer thought it was bad tires so they changed them today. Vibration is still there. I was wondering if any one has had a similar problem and what the solution was. I really dont want the dealer to keep changeing parts until they figure it out. The odd thing is the vibration is only between 45 and 50 mph.
Old May 11, 2006 | 09:03 PM
FortyFords's Avatar
FortyFords
Sounds like a drive shaft balance problem or binding u-joint.
Does the vibration go away in neutral or coast at this speed?
Could be a loose flange on rear diff also or internal carrier bearing inside rear diff.
Rich
Old May 11, 2006 | 09:08 PM
nkfd110's Avatar
nkfd110
The vibration is stiil there even in neutral at 45-50
Old May 11, 2006 | 09:15 PM
ktplotts's Avatar
ktplotts
i got the same problem, but it comes and goes and changes in how bad it shakes the truck, does yours do this? my dealer said they couldn't find a problem, go figure.
FortyFords's Avatar
FortyFords
They need to chk the drive shaft balance or put a new one in.
Rich
Old May 13, 2006 | 01:31 PM
nkfd110's Avatar
nkfd110
Thanks for the info Rich, I have an appointment with the dealer on Monday. I will let you now what happens.
