Lost at the bend.
Old May 11, 2006 | 05:32 PM
94F250_weekender's Avatar
94F250_weekender
Lost at the bend.
94 F250 diesel 4x4 automatic, 4600lb front end....I had what sounded like a clacking from the front drivers side bearing. Now after looking it over apart the left shaft appears to not ride straight in the housing and all the stuff to the hub gets in a bind and won't guite go together without a hammers persuasion. If you look at everything by itself it all looks right and not bent or damaged. Just when its put together it is off kilter. I feel like I am not getting things together correctly. I am just looking over the ford service disk but if anyone can relate to this I appreciate your input.
Old May 11, 2006 | 06:44 PM
Dave Sponaugle's Avatar
Dave Sponaugle
How is the bearing inside the spindle for the stub axle shaft.
Suffering from CRS right now and can't remember the name of that bearing.
