How does a turbo work?
Old May 11, 2006 | 11:23 AM
chixdigit's Avatar
chixdigit
Would someone care to explain exactly how a turbocharger works/ enhances power to this engine?
Old May 11, 2006 | 11:41 AM
Maxium4x4's Avatar
Maxium4x4
Most engines are naturally asperated.
Turbochargers compress the air flowing into the engine. The advantage of compressing the air is that it lets the engine squeeze more air into a cylinder, and more air means a higher fuel rate can be used. A turbocharged engine produces more power overall than the same engine without the charging.
In order to achieve boost, the turbocharger uses the exhaust flow from the engine to spin a turbine, which in turn spins an air pump. Since it is hooked up to the exhaust, the temperatures in the turbine are also very high.
Old May 11, 2006 | 11:44 AM
laredo7mma's Avatar
laredo7mma
Check out (with a www. infront of it):
turbobygarrett.com/turbobygarrett/tech_center/tech_center.html
Old May 11, 2006 | 08:30 PM
Deluxe05's Avatar
Deluxe05
And, another good source of knowledge on the Internet....
http://auto.howstuffworks.com/turbo.htm
Old May 12, 2006 | 12:30 PM
chixdigit's Avatar
chixdigit
Great info guys... thanks a lot.
Old May 12, 2006 | 12:41 PM
saftman's Avatar
saftman
Turbos create "free power" with no parasitic loss. A Supercharger is engine driven and consumes some power while it 'creates power'.
Old May 13, 2006 | 12:43 PM
RVRoadie's Avatar
RVRoadie
So what is the difference between a blower and a turbo? Since blowers are belt driven, is there any such thing as a belt driven turbo? Or, is that the difference.
Old May 13, 2006 | 07:04 PM
Maxium4x4's Avatar
Maxium4x4
A charger or (screw) blower is powered mechanically. A turbo is exhaust driven.
