engine swap
Old May 11, 2006 | 12:24 AM
Davelv's Avatar
Davelv
Question engine swap
i need to know if anyone knows if i can put a 1996 ford explorer motor into a 1992 ford explorer? i was told it was possible. i don't know though need some advise.
Old May 11, 2006 | 09:45 AM
Mike G's Avatar
Mike G
The motor should fit, are you just swapping in the short block?
--Mike
Old May 11, 2006 | 10:55 AM
Davelv's Avatar
Davelv
engine swap
i know the upper intake, the motor mounts, and the engine wiring is different but i plan to switch them around. can i take the 1996 engine harness off and put my 1992 harness right on all the sensors and connections????? TRYING TO PUT A 1996 FORD EXPLORER MOTOR IN A 1992???????
Old May 14, 2006 | 02:41 AM
AlfredB1979's Avatar
AlfredB1979
You might have extra sensors on the 96 block--not many--so you can ignore those if youv'e done everything else properly.
Old May 14, 2006 | 11:43 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
1996 is OBD-II and 1992 is OBD-I...so you will definately run into some electrical differences...
