12v power with key on??
Old May 10, 2006 | 02:52 PM
Thoth88's Avatar
Thoth88
Does anybody know of a 12v key on power supply wire that I can tap into at the fuse box of an '06 Ranger? I need to wire in my acc recepticle in the glove box but I don't need it active all the time. I'm looking for a supply I can piggyback that is energized only when the key is in 'RUN'.
Also does anybody know where the door chime unit is located, other than in the dash? I'd realy like to disconnect it, unless this somehow messes with the 'brain' of my truck.
Thank you.
2006 Ranger XLT
4.0L V6 Manual 2WD.
Old May 10, 2006 | 04:37 PM
Exploder02's Avatar
Exploder02
Don't know about your switched 12V source, might want to try Autozone's website (I think I've seen a few schematics on there)...
Old May 10, 2006 | 05:56 PM
Thoth88's Avatar
Thoth88
I found my desired tap, Grey W/Yellow Stripe at the fuse box. I actualy found it by probing the wires at the ignition.
Old May 10, 2006 | 06:21 PM
dag's Avatar
dag
I was going to suggest a test light, but I'm guessing you got it figured out!!
