Compression worries
Old May 10, 2006 | 10:24 AM
Snowking's Avatar
Snowking
Unhappy Compression worries
The 352 I just got going was sitting for a long time. It wasn't seized, but for a while the starter motor had all it wanted. I had to keep squirting oil into the cylinders but eventually she started to turn smoothly. The longest I have had it running would be about twenty minutes. I just did a compression test.
I had three pistons test 75's
two just under 75
one at 50
two at a dissapointing 10
How much may these improve if any? What can I do other then ripping it apart and start from scratch?
It may have been ran hot in the past I bught it with a leaking water pump and a temp. guage not working.
I think if I could get them all up to 75 I'd be happy, but of course i'd appreciate higher.
Old May 10, 2006 | 11:28 AM
PROSTOCK's Avatar
PROSTOCK
75 sounds awfully low I'm afraid. It could be the rings are stuck. If you had rust in the cylinders then you probably are looking at tearing it down.
Old May 10, 2006 | 02:08 PM
rusty70f100's Avatar
rusty70f100
I'd say go drive it a while, long enough to get the motor warm, and see if the rings will work themselves back in again. Then do another compression test.
BURNSF250
16
Sep 15, 2010 01:35 PM
Greenmillwork
Feb 23, 2009 11:17 AM
1972 Ford Thunderbird 429 V8
Dec 19, 2008 05:42 PM
Rick.Kendall
Dec 2, 2003 06:03 PM
nzabka
Jul 24, 2003 03:44 PM
