ZF tranny swap questions
I am not sure about the slave cyclinder mount on ths side... loudfords - are you saying that all the 460 & diesel ZF's have the mount like this or were you just pointing out what engines used ZF's?
ZF's were actually used in many applications, including I6 300, 460's, and diesels and I beleive 88-95 is what we want, there was something different about post 95 but I cant remember. I even thought they had ZF's on tritons but I am not sure about that. The only one that will bolt on fit the 351M/400 bolt pattern is the ZF that came behind the 460 motor. Someone can correct me if I am wrong but wasnt the ZF the only choice for a 5speed on an 88 & up f250/350 with a 460? My brother in law just wrecked his 88 F350 (which I assume has a ZF) and I pleaded with him to let me part the truck out but he finally decided he was going to try to get it back on the road. Dang.
You have to make a notch in the tail housing to clear one of the shift rails on the 205. Take a gasket made for the four speed and use it as a template for where to grind. The only other modifications that I made were grinding off a couple of "ears" that stuck out on the tranny because they looked like they could rub against the tranny tunnel. I'll take pictures of which ones I ground off. Another thing, I was wrong about the flywheel spacing. The flywheel is 1/2" closer to the block on a 351/400, not further away. I got a pilot bushing for the 400 and put a thick washer behind it to space it out a little, it looks like it's going to work fine. Without the washer behind it, the input shaft just barely made contact with the pilot bushing. I was going to have one made that was 1/2" longer, but I have no idea what those things are made out of. I've heard that they're impregnated with oil, the washer sounded like a much easier solution. The clutch disc also looks like it will work fine without spacing the flywheel out any, we'll see once I get it in there. When I think of more stuff I've done, I'll post it up.
I did the ZF swap into my 78 (see gallery) but also switched to a 460 because of the flywheel thing. So far you are doing most of the steps that I went through in order to make it fit. One thing though, if you are going to use a mechanical clutch setup like I did you will find that you will need to cut and lengthen the ZF clutch fork to give a better leverage ratio-unless you have the left leg of a body builder. It also makes for better push rod angle. Also I discovered that the ZF throwout bearing always rides on the clutch diaphram fingers because the fork has no clips to pull the bearing backwards and hold it in place. At least thats how my setup worked out. Hope this helps.
I think that I have a couple pictures of the tranny. I need to look through all of the pictures that I have taken. I got the tranny and transfercase mounted today and the exhaust back on. I'm going to finish it up tomorrow night, I ran out of time today. Everything seems to be coming together like it should, which worries me. We'll see what happens tomorrow.
#30
I got the thing back on the road yesterday. It's nice to cruise on the freeway at 60 spinning 2000 RPM instead of 2500 RPM. I'm going to load the pictures that I took into my gallery tonight or tomorrow. Everything went about like I thought it would. I lengthened the clutch fork about 3 inches and it feels just like it did before. I also heim jointed the clutch linkage, it works a lot better, no more binding. Thanks for all of the input.
Chris
Chris
