after 140K
Old May 9, 2006 | 07:19 PM
1983_f100's Avatar
1983_f100
after 140K
well ive had my truck for about a month now and she really purs with that 300 in her...but my question is after 140k miles, what engine maintenance can i perform to make sure that she easily sees 300k? thnx in advance fellas...
Old May 9, 2006 | 07:53 PM
RacinNdrummin's Avatar
RacinNdrummin
Dump the six and get a late model 302...
Old May 9, 2006 | 08:09 PM
1983_f100's Avatar
1983_f100
haha, good one man... the only thing im changin on this truck is the suspension and the oil lol
Old May 9, 2006 | 08:49 PM
RacinNdrummin
Run Chevron Delo 15w-40 oil. Its made for diesel engines and has detergents that keep your engine clean and removes the sludge as well. Works better than any high mileage oil and is cheaper. Also change your oil every 2500-3000 miles and Make sure your colling system is up to par.
Old May 9, 2006 | 09:26 PM
1983_f100's Avatar
1983_f100
thnx man...i plan on changin the oil sometime this weekend or next week and i was wondering what else i would besides the oil, filter, spark plugs, plug wires, air filter, and probably some "RESTORE" but besides that what else should i look into to make sure everything is in "tip-top shape"?
Old May 9, 2006 | 11:50 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Why would he want to do that. My 300 will out pull, out perform and drive circles around a 302, last twice as long between rebuilds, and get better gas milage while doing it.
There is a big reason why the 302 was only offered in a half ton truck, but the 300 was offered in everything up to an F-600.
The only advantage of a 302 over a 300, is you can go faster down the road.
As for the other question, just change your oil, and do regular tune ups and you should be fine. that engine of yours should last another 100K easily. I'd like you to do that with a 302, it would be worn out by now.
Old May 10, 2006 | 12:13 AM
81-F-150-Explorer
Originally Posted by 1983_f100
thnx man...i plan on changin the oil sometime this weekend or next week and i was wondering what else i would besides the oil, filter, spark plugs, plug wires, air filter, and probably some "RESTORE" but besides that what else should I look into to make sure everything is in "tip-top shape"?
Change the O2 sensor if it has one. I change mine every time I do a tune up. Good practice.
Check the state of the old plugs, they can tell you some of what is going on. Number them corosponding to what cylinder is which. Can tell you if the truck is running normal, running rich, lean, or if you are burning oil etc...
My plugs are telling me I need new valve guides for instance. Did a compression test, good compression, runs like a top, passed california smog with flying colors etc. What do you expect for an engine with 470,000 on it though.
Old May 10, 2006 | 12:14 AM
littleme13's Avatar
littleme13
change the oil and beat it to death and it will outlast everything else you own. ive owned a 300 with well over 300k and she still wouldnt die. the only thing it was used for was a woods truck where it saw rpms that it should have never in the mud and she wouldnt die. but be carefull not to over heat as thats what killed mine. aparently its not smart to was a radiator that all thats holding it together is mud...lol
Old May 10, 2006 | 07:09 AM
1983_f100's Avatar
1983_f100
i know this has nothing to do with the title of my thread but what bolt pattern is on my truck's wheels? (just for reference)
Old May 10, 2006 | 07:29 PM
RacinNdrummin
You are insane my friend. Im so tired of people like you spreading the propaganda on this site about the 300 being some glorious thing. I have owned 3 vehicles with the 6 (76 E-150, 81 F-150, 94 F-250) All 3 were dogs that barely saw 150K, every 302 I have ever seen has gone over 200k and even a couple (including the one I replaced my six with in my 81') saw over 300,000 . All you have to do is look at the peak power ratings, numbers DONT lie. The 300 never had the torque, let alone horsepower of a 302. and GAS MILEAGE??? you would be happy to get 14 frwy with the six, my current 302 in my 81 that doesnt have the most mpg-friendly engine(.030 over, holley 600, edelbrock intake, comp 270 cam, headers) gets 18 with 3.50:1 gears. The 6 is garbage, if I have to pull your truck backwards down the street to prove it, I will.
Old May 10, 2006 | 07:39 PM
srercrcr's Avatar
srercrcr
Sorry, Racin'.....your credability is shot to hell. Your right, numbers don't lie...both 300 and 302 have the same peak torque ratings, the 6 at 1600 rpm, the 8 at 2000.
Perjury, my friend.
I've had my 300 since '83. Oh did I mention 20 mpg highway, SuperCab and long bed....heavy. Was that you I passed yesterday at the gas station?
I challenge any 302 owner to match my numbers.
Old May 10, 2006 | 08:57 PM
RacinNdrummin
Perjury, my friend.
The 300 does not have 305 lb.ft of torque, stock my 69' 302 does, the 300 is somewhere down around 260. You need to look up your power ratings more often, go and buy a chiltons or something. And 400 rpm is nothing my friend. As for the 20mpg, LB SC with a SIX??!!, Im afraid your credability is shot to hell, there is no way in hell thats true, especially with a carbed six and YOU know it. Tell me how my credabilitly is shot when I have had enough expirience with the six, probably more than you, to know what im talking about, the engine is garbage. Ill pull your truck backwards down the street as well.
Old May 10, 2006 | 09:33 PM
andym's Avatar
andym
There's so much wrong with that post I'm not even sure where to begin. I'm not sure you'd know a 300 if you saw one, never mind ever driven one. The only thing you'll be towing around with your 302 is your huge crock of ...
Old May 10, 2006 | 09:48 PM
RacinNdrummin
Obviously you didnt read my second to last post Moron. At least my truck will pull something. And if your so right, wheres the facts??
Old May 10, 2006 | 11:37 PM
jpjahn's Avatar
jpjahn
The guy just wanted to find out how to make his 300 last.. You can't make a 300 last longer by putting in a 302...If you do that, your cheating...
