Sponsored by: Real Truck
A/C Vent
Old May 9, 2006 | 07:37 AM
troy1059's Avatar
troy1059
A/C Vent
Hey guys, I have a 1998 f-250 super duty xlt 7.3 diesel. The prob I have is that the a/c is blowing cold through the defroster vent but not the normal vent. I have no power to the vaccuum pump that regulates this. I can get the vaccuum pump to work and to vent properly by jumping the vaccuum pump off the battery, but when I turn the truck off and restart it the a/c vents through the defroster only again.I also numbered and switched around all the relays and this didn't do anything either.Any clues, thanks guys, Troy.
Old May 9, 2006 | 09:27 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 9, 2006 | 02:02 PM
devildog_0431's Avatar
devildog_0431
If it works properlly if you jump it giving it power then just run a new power wire to it. Check for a blown fuse, I can't find much more in my manual.
Old May 9, 2006 | 02:31 PM
krewat's Avatar
krewat
Check for fuses...
Check for broken wires going to the vacuum pump.
Otherwise, I might move this to the 7.3 forum soon, where you might get a lot more answers.
