towing questions
Old May 8, 2006 | 11:41 PM
mikehoward2's Avatar
mikehoward2
towing questions
I have a 1997 super cab f250 psd, towing a 31' fifth wheel that weighs roughly 11500lbs my tranny is auto e4od. am i supposed to tow in od off mode, when i do it sounds like it is wound tight at 60mph(2200 rpm) i want to go into od so bad, is that alright. Or can I change rear end gears, dont know mine but what ratio is best for towing.
Old May 9, 2006 | 12:33 AM
ForemanES's Avatar
ForemanES
Sounds like you have 3.55 gears in it. I have heard that it is ok to tow in od as long as the tranny doesnt "hunt" for gears, like in the mountains. I have 4.10 gears and in 4th gear (5-speed manual) I am almost to 3000 rpm at 60 mph, 4.10s are better for towing and give you a higher trailer weight capacity. You should be fine towing your 5th wheel, just dont get your rpms too low and lug the motor (high egts)
Old May 9, 2006 | 01:06 AM
1997F-350's Avatar
1997F-350
the motor is fine at those rpms. on an unmodded truck i know it sounds a little scary. but its fine. its due to the exhaust and intake being so restrictive. open up a little and it will sound fine or leave alone and its ok. get some gauges so you dont get your tranny to hot. other than that it should be fine.
Old May 10, 2006 | 10:11 AM
Rikc1's Avatar
Rikc1
Mike-
I have a 97 crewcab 2wd I tow a 33' fifth wheel about the same weight, I will kick it in overdrive on the interstate and have had no known problems. In town, winding roads, and mountains it's a gimmie leave it off. I do have some mods done to my truck, if your all stock I would recomend the larger trani cooler and temp gauge to ease your concern. It's just being smart on the interstate take the od off before you start up the hill and passing. I just re-read what I typed up the hill and passing made me think back before the powerstroke, I hated hills. As for the gears I thought I would have to change them out. Instead I put the money on other mods and gauges and am glad that I did.
Old May 10, 2006 | 11:43 AM
Phydeaux88's Avatar
Phydeaux88
Don't worry that you are over revving at 2200 RPM. I have a 96 F-250 PSD and tow a 34' fiver. As soon as I encounter hills I drop out of OD and continue to run 60 to 65 MPH which puts me between 2200 and 2500 RPM.
Your PSD will run all day long at that speed.
The main reason for down shifting is to keep the tranny from overheating.
You can add an under/overdrive unit behind the tranny that will give you a gear between 3rd and OD I have been considering one for some time and am about to make the move.
There are two that I have looked at: GearVendors and U S Gear. They each have pros and cons. Be prepared to spend some $$$ if you choose that route
SoCalAngler
Mar 25, 2016 05:31 PM
garagegods
Jul 5, 2015 08:16 PM
silvers
Jun 16, 2006 04:11 PM
MORTORQUE
1978 - 1996 Big Bronco
Oct 9, 2004 11:01 AM
Torstein
May 5, 2003 10:01 AM
