Extending mirror maintenance
Old May 8, 2006 | 10:06 AM
Downriver Thunder's Avatar
Downriver Thunder
On the arms where the paint flakes off, what have you guys, (if any), done to repaint or fix this?
Old May 8, 2006 | 11:56 AM
Matt M, PA's Avatar
Matt M, PA
Mine are natural black plastic....were your painted for some reason? Or is it just scuffed plastic?
Old May 8, 2006 | 12:58 PM
Downriver Thunder
No, the two arms on my X and my companies super dutys are metal arms that attach to the mirror.
Old May 9, 2006 | 11:13 PM
RACERX7775's Avatar
RACERX7775
metal????? mine are factort tt mirrors and there is no metal on the outside of them except for the chrome covers.no paint either. it is just black plastic..
Old May 10, 2006 | 10:39 AM
Downriver Thunder
Well, I just don't know. The two arms going from the mount to the mirror are aluminum of some sort and the paint is pealing off.
Old May 10, 2006 | 11:21 AM
Downsized2X's Avatar
Downsized2X
Diesel User
I see the metal bars on a lot of passing Super Duty's mirrors. It looks like a common problem. I would definitely paint them or maybe consider power coat.
Old May 10, 2006 | 11:28 AM
rlh68050's Avatar
rlh68050
Must be some realy early build or something. I looked at your gallery and still can't tell that the mirrors have any metal parts. They look just like mine which are all plastic.
Old May 10, 2006 | 01:05 PM
Downriver Thunder
I know they look like they are plastic, the paint is textured but if the paint wasn't there you have dull aluminum.
Old May 12, 2006 | 10:09 PM
Btravelen's Avatar
Btravelen
The adjustable parallel arms that support the mirror head are aluminum that is powdercoated, or maybe just thick textured paint. The coating started to peel on my '00. I was going to touch them up with some black paint but I traded it before I did.
Old May 16, 2006 | 04:55 PM
ryaneverk2's Avatar
ryaneverk2
Those who think you have plastic arms that support the mirror... scratch off some of the paint and you'll see that they're metal. If you've never had the mirrors off... they're pretty heavy. They have a full metal support structure inside, as well as the metal structure underneath where it mounts to the door. I guess Ford figured that plastic wouldn't be good enough to hold up to that weight and stress of them hanging out there. I for one am glad they're metal.
The lower arm on my passenger side mirror has a small spot on the front bottom of it, maybe the size of a nickel, where the paint's chipped or peeled off. I don't really notice it much but I suppose I'll just use a little black paint to touch it up someday...
