need help with tires
Old May 7, 2006 | 11:37 PM
OneSweet81's Avatar
OneSweet81
Question need help with tires
ok guys i have a few questions about tires i have a 1981 f-150 with lightning wheels and i lowered it 3in and i currently have 295/45/18 on the truck but i need two more tires i found a good deal on some 275/40/18 would look ok if i put the 275 in the front and kept the 295 in the rear thanks for the help trevor
Old May 8, 2006 | 07:55 PM
bluesuedetruck's Avatar
bluesuedetruck
From what I remember about radials, mixed tire size will work as long as the fronts match and the rears match.
Old May 8, 2006 | 08:40 PM
surewhynot's Avatar
surewhynot
It should be fine. Looks like the rears will be a little taller and a little wider. Here's where I converted the tire size- http://www.4lo.com/calc/gearmetric.htm
