My "new" 72 F250 mud truck is not charging the battery. The auto parts store tested my old alternator as bad. I bought a new one that looked identical. I pulled off two wires from the back of the alternator when I removed it. When I went to hook it back up, I couldn't remember which wire went where. There is a red and black stud on the alternator. I also have a red and black wire. Sounds too easy doesn't it? Wrong! The red wire is a push on connector that will not fit on the red capped alternator stud. The black wire has a ring terminal that will go on either black or red capped stud. Common sense says red to red, and black to black. The red cap is just too small for the red stud. The alternator studs are not labeled, just red and black. I do have 12v on the black wire coming from the battery, and the red wire goes to the voltage regulator. Is the red stud indicating 12v, and I need to hook the black wire to the red stud? The engine is a 460 supposedly out of a special order 73 Galaxy that was transplanted many years ago. Which wire goes where????????
Also I only have two wires going to the alternator. Shouldn't there be three?
Hi, the large stud is the output to the battery. The back of the alternator should have the connectors labeled. The F or field terminal goes to the field connector on the voltage regulator. The Gnd or ground terminal goes to ground. Sounds like this is the one someone left off. The last connector is the Sta or stator. It is at the top rear of the alternator. It is normally not used, can be used on a electric choke. Also, the ground connector is not isolated from the case.
First create a gallery.
In this gallery create a illustration/photo album.
In this album that you will HIDE from public view,upload a photo about 28KB in size.
Once that photo is uploaded > scroll to the photo and click Forum codes > In a window two codes will show up.
The top code is a full-size photo and the bottom one is a thumbnail photo.
With your cursor(mouse) left click holddown *completely* highlite the top code and then right click the mouse then left click *copy*.
Now head for the thread in the message boards that you want to pst the photo to.
left click the mouse to get the cursor into position for posting the photo > Now right click the mouse > then left click *PASTE* type whatever words you want to add and click *Preview* if it is good to go click * Post message*
