Sponsored by: Real Truck
blocks in the front?
Old May 7, 2006 | 09:42 PM
danny_g_76's Avatar
danny_g_76
I saw a 99 f-250 toady and it had blocks that looked like huge hocky pucks un the front suspension. he said it is for plowing. It keeps the front of the truck from dropping when you put the plow on and when you are plowing. I need them in my truck. any one know what they are called or where i could find them. Thanks Dan
Old May 7, 2006 | 09:58 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
From everyone here, I've learned that blocks in the front is usually not a good idea.
A stiffer or higher-arc spring would be the way to go for that, or what they call a "leveling kit".
There's a reason for the "plow" package. Mostly uprated front springs, sometimes (always?) a heavier-duty front axle.
More people will join in very soon, I'm sure, and dispense lots more information than I have
Old May 7, 2006 | 10:01 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
no no no! no blocks for the front end! it throws off steering geometry, and it is extremely dangerous because of the side loads that the leaf springs see. the turning axle on any vehicle should NEVER have springs. it would be too easy to turn too hard and make enough force to dislodge a block and have a real big problem. stick to a leveling kit (which i have, check my gallery) or add-a-leaves. a leveling kit will most always not increase load capacity, but will keep ride smooth. add-a-leaves will increase capacity while increasing the harshness of ride factor too...
Old May 7, 2006 | 10:37 PM
be250's Avatar
be250
they are not blocks
hi, i have them too, they are called timbreins, 'not rightspelling'. got mine at awdirect. they work great ,barry
Old May 7, 2006 | 10:39 PM
ford390gashog's Avatar
ford390gashog
blocks in the front is super dumb use higher arc springs instead.
Old May 7, 2006 | 10:51 PM
EnviroCon's Avatar
EnviroCon
Before you bite the poor guy's head off. I believe he is talking about the Timbren SES system that be250 mentioned. It doesn't go under the springs, it goes above them between the frame and the top of the spring. Here's the website-->http://www.timbren.com/
Old May 8, 2006 | 12:23 PM
kaipo's Avatar
kaipo
NO blocks in front ever.
Old May 8, 2006 | 08:07 PM
be250's Avatar
be250
again they are NOT BLOCKS!!!!
they are rubber springs. they help carry the extra load of a snow plow ,thanks barry
