Installed Powerslots & pads, now pulls left?
Old May 7, 2006 | 09:23 PM
Fountain38's Avatar
Fountain38
Installed new rotors - powerslots, and ceramic pads on my 2004 Ex, (26,000 miles). After all put back together & tested over last two days it seems to pull to the left when braking. I did not bleed the brakes, just unbolted caliper & loaded in new pads and reinstalled. Any ideas what to check?
Also noticed front two tires show weird wear pattern. On each tire, individual lugs are worn higher or lower than lug next to, behind or in front of. Rear tires are smooth as normal. I bot this Ex with 17,000 miles and have not rotated the tires. BF Goodrich Rugged Trail T/A. Alignment seems fine. Thanks, Dave
Old May 7, 2006 | 09:35 PM
NC Medic's Avatar
NC Medic
Sounds like you have a rotor problem it could be the thickness of the right one is thicker
Old May 8, 2006 | 08:01 AM
rlh68050's Avatar
rlh68050
Hey, I have the same issue with my Ex now. I too just did a complete brake job, and the damn thing has a slight pull to the left now. I am thinking that the right caliper may be hanging up a bit now. I am going to take it off, open up the bleeder, and push the pistons in again to see if they are moving freely. Also, I will bleed the brakes too. If not, I guess I will get a new caliper for that side.
As for your tires, it looks like the previous owner never rotated them. The fronts will wear like that if they are not rotated to the back. I rotate mine every other oil change (about 6k miles).
Old May 8, 2006 | 05:07 PM
Fountain38's Avatar
Fountain38
I may go ahead and bleed them, But that shouldn't do anything as I did not open up system. Standard brake fluid or special? I guess I'll rotate tires, mayt stop by dealer for quick look.
Old May 11, 2006 | 08:36 AM
rt7500's Avatar
rt7500
Always bleed.
The wear you are seeing on the tires is due to alignment. Have it checked. With that description of tire wear. Very possible that a ball joint may be going bad.
I had the same thing happen on my '00 X with the Powerslots & Hawk Pads. Bleed the passenger side first then the drivers side. All should be good. Always start your bleed the furthest from the master cylinder.
Hope this helps.
Old May 11, 2006 | 08:56 PM
Fountain38's Avatar
Fountain38
Tire store said tires just need to be rotated, which they did. Truck tracks very true when driving, so I thought alignment was ok.
Brake guy told me sometimes ceramic pads take a short time to set & be patient. Said I could also swap pads from side to side & note effect.
Thought I'd be going camping this weekend, but the "monsoon" storm system in midwest changed our plans
Old May 11, 2006 | 09:58 PM
aklim's Avatar
aklim
I flush the brake lines ever other year with Dot 4 Castrol Synthetic fluid
