Dead PSD
Old May 7, 2006 | 08:50 PM
Big Sky Stroker's Avatar
Big Sky Stroker
Unhappy Dead PSD
Driving home this eve, my 2002 7.3 PS died. It will not even attemp to fire. It turns over fine but no smoke. Any ideas?
Old May 7, 2006 | 08:58 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Sounds like the fuel is shut off to engine.
Old May 7, 2006 | 09:40 PM
CanadaGuy's Avatar
CanadaGuy
I'd suspect the camshaft position sensor is done.
Old May 8, 2006 | 05:45 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved ..................enjoy
Old May 8, 2006 | 05:48 AM
lancer's Avatar
lancer
I'm with Canadaguy on this one. Your cps is mostlikely your prob!! Good luck!
Old May 8, 2006 | 06:26 AM
Tenn01PSD350's Avatar
Tenn01PSD350
I'll be first then, welcome to FTE Big Sky. Yup, if it just quit outta nowhere and won't restart, likely the CPS. Lot of other things it could be like lack of fuel, GPR, GPs, not enough battery juice, but 9 outta ten times with your symptoms it's the old CPS.
Old May 8, 2006 | 07:56 AM
toproller's Avatar
toproller
I'll make it three , my bet is it is the Cam Sensor. Mine has gone twice in 5 years. Good Luck
Old May 8, 2006 | 08:56 AM
ballbandit's Avatar
ballbandit
One way to check cam sensor is to crank it over if the tach doesnt move then its the sensor,if does then it is something else.
Old May 10, 2006 | 09:46 PM
Big Sky Stroker
Thanks to all that responded. It was the cam sensor. I will carry a spare with me. Especially on the way to Alaska. It could be a handy thing to have.
Thanks again to all
Old May 10, 2006 | 10:04 PM
arninetyes's Avatar
arninetyes
Yeah, they really don't fail all that often - but when they go, no engine.
Old May 10, 2006 | 10:50 PM
GeoffNJ's Avatar
GeoffNJ
Does SpringerPop still want dead CPS's? Just in case, don't toss it.
Old May 11, 2006 | 12:07 AM
SpringerPop's Avatar
SpringerPop
I've got a couple ahead of me to review, so hold off sending me any CPS's right now.
Pop
Old May 11, 2006 | 05:43 AM
GeoffNJ's Avatar
GeoffNJ
I still have my new one in the glove box. I've often thought of just changing it out to see if there's any difference. The truck runs great. A little hiccup or pulse once in a while. Who knows?
Old May 11, 2006 | 10:50 AM
hott-rodd's Avatar
hott-rodd
GeoffNj , I'd put the new one in to be sure it's the right one.
Then you would KNOW that you have a good spare.
Unless you have the factory FORD CPS.
Old May 11, 2006 | 02:21 PM
Kwikkordead's Avatar
Kwikkordead
That would be the CPS sending a "dirty" signal that the ECU has a hard time desciphering. Change the CPS.
