bad modulator valve or somthing else ?
Old May 7, 2006 | 08:03 PM
Channelcatjohn's Avatar
Channelcatjohn
78 F-250 I replace my modulator because I had fluid in my vacuum line. But I still have the same problem? Does anyone have any input on this? Also my kick down seems to be not working? i just installed a edelbrock intake manifold to handle the 4 barrel holly truck advenger,runs great. But no kick down and tranny seems a lil bit slug age <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old May 8, 2006 | 08:20 AM
stuart1's Avatar
stuart1
Did you clean the oil out of the vacuum line?
Maybe it's left over.
If you swapped carbs you will have to find the correct kd linkage.
Old May 8, 2006 | 05:37 PM
Channelcatjohn
tranny fluid in modulator vacuum line
i replaced the line also, could it be somthing other than the modulator valve ?
i have a funny feeling it is
