Clutch problem
Old May 7, 2006 | 06:06 PM
compaddict's Avatar
compaddict
Clutch problem
My clutch sometimes doesn't completely disengage. Around 15% of the time when I'm at a stop sign it's hard to get into gear and about 2% of the time I have to shut the engine off to get it into gear. The truck has always been a little hard shifting. The engagement point feels about perfect (a third off the floor).
The PO had replaced the clutch and slave cyl. (had done at a transmission shop) to fix the problem with no love. I just replaced the clutch master cyl. with no love. Pumping the clutch doesn't help.
I have a 92 F150 4x4 with an I6 and 5 spd with 90k.
I would appreciate any ideas!
Vince
Old May 7, 2006 | 06:20 PM
wildcard30's Avatar
wildcard30
Does the truck creep when it's in first gear, with the clutch pressed, at a stop light?
Do you have problem shifting at other times, ie 2nd to 3rd, or downshifting from 2nd to first?
Old May 7, 2006 | 09:42 PM
compaddict's Avatar
compaddict
When it's at its worst (2%) I can feel that the engine is not completely disengaged but it's not enough to start the truck moving.
On a scale from 1 to 10 (10 being easy) I would say the difficulty of shifting most of the time would be a 6. 30% of the time I would give it a 3.
Vince
Old Jun 2, 2006 | 09:36 PM
compaddict's Avatar
compaddict
Bump!
Vince
Old Jul 9, 2006 | 04:55 PM
slpin's Avatar
slpin
i have the exact same rpoblem
Old Jul 9, 2006 | 07:58 PM
kotzy's Avatar
kotzy
Sounds to me like a tight pilot bushing, dragging the input or as some call it the clutch
shaft along when it should stop. Some guys get carried away wanting that bushuing too darn tight.
Old Jul 9, 2006 | 10:53 PM
compaddict's Avatar
compaddict
I'll let you know what it was. My tranny went crunch/grind/freespin and it's all coming apart and going back together this weak.
Vince
Old Jul 10, 2006 | 01:49 AM
slpin's Avatar
slpin
so far, this is what i am suspecting because i know the pressure plate should be disengaging it all the way
it makes sense when it does it when it is hot too...
so now what do i do... clutch in, tranny in gear, and just hold it at 5k for a few hours and hope i kinda loosen it? hahaa
Old Jul 11, 2006 | 10:26 AM
compaddict's Avatar
compaddict
My transfer case exploded inside. The truck is back together and the clutch was inspected and given a clean bill of health.
My clutch problem persists..
I'm going to bleed the system myself.. It really feels like air in the master.
Vince
Old Jul 11, 2006 | 09:07 PM
compaddict's Avatar
compaddict
Gravity bled today with the truck on my driveway (master pointing up) and it made no difference. What kind of weird bleed screw is that anyway?
I'll bleed it again when I can get an assistant to pump on top with me opening and closing the bleed nut.
Vince
Old Jul 12, 2006 | 09:16 PM
compaddict's Avatar
compaddict
Fixed! After bleeding the system with the truck on enough grade to have the master cylinder pointing up and and assistant pumping while I was on the ground releasing the bleed screw worked. I have love!
Vince
Old Jul 13, 2006 | 09:50 PM
compaddict's Avatar
compaddict
Worked for a day.. When I backed up my driveway (very steep) a air bubble in the master cylinder came back. I'm bringing it to a shop and having them pressure or vacuum bleed the damn thing.
Vince
Old Jul 14, 2006 | 04:08 AM
slpin's Avatar
slpin
really
i am goign to retry bleeding it then!
but i dont think it would help because my clutch engages at the very top already!
Old Jul 17, 2006 | 08:31 PM
compaddict's Avatar
compaddict
Took the truck to a friend of mines shop and they went through four more flush cycles and it is 90 percent perfect.
I'm going to put a speed bleeder on the transmission and do it a few more times.
Part number SB7100S.
Vince
Old Jul 18, 2006 | 09:32 AM
katzmanfam's Avatar
katzmanfam
I have the same problem with my mod5 trans 4x4 I6 (87). I have tried the bleeding rout with little suceess. It is a frustrating problem with these hydrolic clutches.. Any one find a cure? The transmission has less than 15k mi on it. I do not think the shop put a new slave in when they installed it.. To replace the transmission has to be pulled $$.
