2 stroke weed eater motors (rant)
they all suck!!!
Not a single one will start and run. all had the same problem, fuel lines. I gave up on all but the 4 stroke pro. I went to the local power tool shop the specializes in these and wanted to buy some fuel line. Guess what? they don't carry it and can't get it.
One thing that really pisses me off is when I pay hundreds of dollars for tools that don't work and are so hard to get SIMPLE parts to fix. I've even tried to pull fuel lines from the others and they are brittle too.
And when they did run, you spend way to long getting them to start (and yes I did use fresh fuel)
What ever happened to making a tool that LASTS ??? It seems like once they sell the product and have your cash, they just don't care anymore.
sorry, but this just really bites me!
Companies like Shindaiwa, Redmax, Tanaka, Stihl, and others. They all make reliable equipment. I honestly have a hard time figuring why people still buy the cheaper brands. It certainly is not value. Most of the big box store brands have a life span of 50 hours. And trust me, 50 hours is over estimating. They generally start having problems that lead them to the dumpster way before that mark. Yes, you will spend over $200 for a good straight shaft trimmer. You might even get dangerously close to $300 even for 21cc model in certain brands. But 21cc of high-quality cannot be compared to cheaper stuff with a bigger engine, these little engines overpower them. You also will have something that will last for years and years. Would you rather spend $250 on something that is going to run when you want it to, or spend $100 on something that might go one season before it gets tossed? Don't take it as me being critical of you
I have a good friend who has a garage full of brand new, cheap, junk equipment that he bought last week for his son to do their yard. If anyone should have known not to buy this stuff, it was him. I thought I had beat it into his head the last time they bought a garage full of new, cheap, junk equipment for his son to take care of the lawn with. It all broke down and they hired the neighbor to do it. And it will happen again this time. I guess maybe he figures his son will break down before the equipment...that's a tough call
While you probably don't need to buy a commercial-grade gas-powered tool the really cheap stuff tends to have starting problems. The honda tiller we have starts on the first pull, every time, no matter how warm, cold, sunny, not sunny the weather is and I've done nothing other than put gas in and pull the cord.
If it's not starting, it's probably the carb, or something carb-related. That's always been the problem for me when something doesn't start, and sadly, my ability to fix small-appliance carbs is limited to excessive swearing and spraying gumout.
Dave
Ive owned Echos and Stihls in the past and they worked great.
Ive got a 4-cycle Honda trimmer now that has been good so far. The Honda was kinda pricey, but I think that moving up to a 4-stroke was worth every penney it cost me.
or try www.towerhobbies.com
Speaking of different brands and what not, What do ya'll think about echo trimmers? my 8 year old weed eater featherlight s on its last legs.
I remember my dad having the same Weed Eater trimmer for like 15 years and the thing was never taken apart, not even the carb and it was used for some commercial use when he was younger and trying to get ahead with some side jobs. I know that thing had to have had 250hr on it because when I was 16 I was doing about 8 lawns a week myself and still used that same weed eater. It finnaly craft out about 5 years ago but I have to say I was always impressed how long that thing ran. It was a bear to start though and always took like 8-10 pulls with the right choke settings each time.
I, on the other hand, bought a 4 stroke brigs trimmer. It starts on 2-3 pulls the first time and then 1 from then on. It idels nice, is half way quite and has TONS of power. I can say I am very impressed with it and I would be hard pressed to buy anything but a 4 stroke from now on. There are like 4 trimmer companies that use the same engine and just put their shaft on it and I don't think I would hesitate to buy any of the four. I can't remeber what brand mine is, but I know that craftsman used the same engine and has a better trimming head then the version I bought. The other thing is they're pretty resonable at $200 (I bought mine for $160 shipped from somewhere off of the net). My only complaint is they are a little cold bloded, once you start it you have to let it warm up for a minute or two before it'll run really good, I gues its the down fall you get since it's not a honda but then again it was only $200.
We have an Echo blower, too, but it is crap. The handle is designed all wrong, so that if you hold it so you can reach the throttle, you aren't holding it where it is balanced, and it is extremely tiring to use.
In early 1998 I wandered into a dealership that was closing out Shindaiwa and I bought a T230 trimmer. I quickly replaced all my Echo stuff when I discovered how good they were. I still have T230s with 1000+ hours and 8 years old running good. Some have needed carbs, some have needed recoils, but they have been the most durable I have used.
A few years ago Shindaiwa started bringing in the T231, T261 and T272's with catalytic converters to replace them. I don't have any of those and have since started using Redmax equipment due to dealer availability. They too have been perfect running machines. In the next few weeks I may pick up a couple Tanaka's to run. I have had nothing but good luck out of the hedge trimmers and you can get into a commercial unit for about 2 bills through Russo's in Illinois. So I might give them a shot, I always like trying new stuff when the price is right
Speaking of the price and why people buy cheap, I know, that's how things work today. People like price, durability is not in the top three as far as the reasons they purchase a particular item. They see a price of $100 and think that sounds cheap for something like that. It is in their favorite store, so they don't have to make a special trip to a mower shop to buy. I think you are doing yourself a great disservice by doing this though. Don't buy lawn equipment from big box stores. The third reason is because they have a credit card for whatever store with a "great financing offer." Durability comes after all these.
I almost bought a Stihl not long ago but since I still mow a few yards that he has picked up to pay for hs new Zero turn (and then I do mine afterwards) I just use his Echo.
Now the leaf blower thing still baffles me, why in the world he decided on buying a Craftsman leaf blower is beyond me?
