distributor swap
Old May 6, 2006 | 10:19 PM
kenpobuck's Avatar
kenpobuck
distributor swap
will a pionts style distributor fit into a 86 302 i know most say newer stuff is better but i like pionts just need to know if it will fit. thanks for any help
Old May 7, 2006 | 09:15 PM
Franklin2's Avatar
Franklin2
Yes, it will. Make sure you get the old style coil, and a resistor for the coil + wire. Follow the sparkplug wiring order on the engine you have now if it's a 302 HO. It will have the 351w firing order if it still has the HO camshaft.
