Hello!!
The passenger window makes some sort of noise when rolling up like there's an interference inside the door between some moving parts. A slight grinding on the way down and a sharp click/pop about half way back up.
The A/C compressor started cycling off and on today what I would consider excessively (less than 60 seconds between engage/disengage). It also appears to be much noisier than acceptable at idle as well as a lot of generally odd hissing/pressure noise after the engine is shut off.
I just bought the truck wednesday and I will be taking it in this week, so hopefully everything can be taken care of. I like the truck so far, just expected more initial quality than this.
Anybody with same issues or info that could point me in any helpful direction please let me know.
Thanks!!
If you get a minute check out the link here, it will help you to navigate around and understand this site.
To find out where to ask this question, click on this link
https://www.ford-trucks.com/forums/s...88#post3272088
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards.
