Differences between 4x4 and 4x2 C-6?
Old May 6, 2006 | 08:11 PM
davidsca's Avatar
davidsca
Hey all,
what is the major difference between a between 4x4 and 4x2 C-6? I have seen pics of both, but don't really understand the short tranny that bolts to a transfer case and the standard that bolts to a u-joint.
If I buy a 4x2 tranny, what do I need to do to make it work for a 4x4?
All answers are appreciated
Dave S
Old May 6, 2006 | 08:16 PM
stuart1's Avatar
stuart1
You will have to have the correct output shaft to use in a 4WD application.
Old May 6, 2006 | 08:24 PM
davidsca's Avatar
davidsca
Hey Stuart,
ignernt noob question here. Can I swap out from my existing c-6 when I get the replacement, or should I get a new one?
Old May 6, 2006 | 08:28 PM
stuart1's Avatar
stuart1
Yes you can use the one you have but it means ripping the transmission apart.
Old May 6, 2006 | 08:33 PM
davidsca's Avatar
davidsca
Hmmm,
best bet would be to find a replacement c-6 from a 4x4 then. Drat, hoped it would be a bit easier than that.
Back to the drawing board
bruno2
Oct 16, 2011 11:04 PM
T1R1
Feb 25, 2007 11:19 AM
stormr
Apr 21, 2002 11:07 AM
Dmaas17
Feb 16, 2002 04:06 PM
dave186
Jun 1, 2000 01:56 PM
