Timing? novice question
Old May 6, 2006 | 04:44 PM
Cyberbug's Avatar
Cyberbug
Question Timing? novice question
I have a f150 , 1994 5LV8, EFI w/MAF, 302
Does the timing on this require adjusting? can't find the answer. I remember on the old cars you could adjust the timing.
Old May 6, 2006 | 10:35 PM
jroehl's Avatar
jroehl
Unless the distributor has been messed with, it shouldn't require any timing adjustments. But, if it does, you have to pull the little SPOUT connector (it takes the computer advance out of the loop, it's a gray or black jumper connector near the ECM and firewall), loosen the distributor hold-down bolt, hook up a timing light, and twist away on the dizzy. Timing for these motors is 10*BTDC from the factory.
Jason
Old May 7, 2006 | 08:37 AM
Cyberbug's Avatar
Cyberbug
Thank you sir , I couldn't find this info on the net
I will get a timing gun in future and check the timing.
regards,
