Fomoco intake?
Old May 5, 2006 | 05:54 PM
Trailcat's Avatar
Trailcat
Fomoco intake?
Finally took the extra intake manifold off the passenger seat of my truck I just got. Was kinda dirty so I took a wire brush to it and found "FOMOCO" on it. I figured it meant ford motor company, but wasn't sure if it was the stock one or not. It goes to a 360. Thanks.
Old May 5, 2006 | 06:10 PM
STGFordCrazy04's Avatar
STGFordCrazy04
probably an older intake because I think Ford stopped using FOMOCO in the late 60s to signify their parts. Good thing is that FE motors were produced in so many years and in so many different sizes that the parts are rather easy to find and interchange with each other.
Old May 7, 2006 | 09:13 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
If it's cast iron look for a casting number and a "S or T". If there is just the fomoco oval and the firing order it could be an old aluminum intake. Some have a date code by the thermostat inlet. If it's heavy and almost makes you lose the boys while lifting it it's iron. STG is correct that early intakes had no casting numbers. 63 was the first year casting numbers appeared on intakes. So give us a little more info if you can.
G.
Old May 7, 2006 | 06:43 PM
sierraben's Avatar
sierraben
That's what I have laying around in my garage.
An aluminum 4 bb. intake manifold with a Ford casting number (C5AE-9425N).
I think it's from the mid 60's.
It also has a rectangular FOMOCO logo between the 2nd and 3rd runners.
And the firing order on the 5th runner.
I use it as a paper weight.
Old May 19, 2006 | 02:21 AM
troubleinnc2's Avatar
troubleinnc2
hi sierraben,I have my fathers old 70 F100 360,c-6.He passed away 3years ago.He wanted a 390,but the guy really messed him over.I freshend up the old 360 for him but now I have a 390 to build like He wanted.It will take me awhile to get it like He wanted ,but I will,and I know He will be proud as will I.I like that intake,can we talk? Hello to everyone here,Thank You.
Old May 19, 2006 | 03:20 AM
sierraben's Avatar
sierraben
troubleinnc2, first of all, welcome aboard. First post.
I know it's been 3 years since your dad passed away, but still my sincere condolences. He must have died young.
I am planning an engine rebuild on a 65-352 and will probably be using that intake manifold.
If by chance I do decide not to use it, I'll give you a PM (private message).
Post some pics on your progress on the engine rebuild and your 70 F100.
Old May 20, 2006 | 07:14 AM
scamardo's Avatar
scamardo
TroubleinNC,
I am in Gastonia, not to far from you. Have you thought about a Edlebrock intake to use or you trying to keep it original?
Old May 22, 2006 | 12:14 AM
troubleinnc2
scamardo Dad wanted it that way and so do I,but I may have to use aftermarket.Time will tell,Iwill just do the best I can,you know, we all have more time than money, we hope ha ha.
