Engine wont fit
Old Jun 3, 2002 | 11:03 PM
1968F250LWB's Avatar
1968F250LWB
Engine wont fit
Old Jun 6, 2002 | 12:27 AM
TKONO's Avatar
TKONO
Engine wont fit
How the heck do you fit a 7.3 diesel into a 67 F-250? Trying to mount the thing is giving me fits, but I think it will be cool if I can figure it out. Has anyone done this? I have it sitting so everything clears, exhaust, starter, etc. but I dont see a good way to nail it down. Any suggestions would be welcome, thanks!
John
Old Jun 6, 2002 | 04:50 AM
jowilker's Avatar
jowilker
Engine wont fit
John, After measuring several ways, you still feel that it will work, I would pull the front clip and start the engine/tranny fit. That way you have more freedom to work, and with a bud you could keep check on the sheet metal fit. Have fun.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Jun 6, 2002 | 08:09 AM
evans's Avatar
evans
Engine wont fit
Get all of the mounting parts and hardware from the truck that the engine came from (or a similar truck). Including the mounts that bolt to the frame. Try to adapt them to your truck frame. It will probably take some cutting grinding and welding. I don't know if this will work or not but it's what I would try first. Sounds like a cool swap. Good luck!
Mike
Old Jun 6, 2002 | 10:39 PM
TKONO's Avatar
TKONO
Engine wont fit
The main trouble I am having is the motor mounts from the diesel do not match the 67 whatsoever. If I could get some mounts that would bolt up to the 67, it would be no problem, but the drivers side mount is 5 inches from the crossmember and I'm having trouble trying to find a way to make a bracket to fit between the engine and frame without getting in the way of the steering box. Thanks for the suggestions,
John
Old Jun 6, 2002 | 10:47 PM
whitebenz's Avatar
whitebenz
Engine wont fit
When you figure it out please let us know what you were able to do. I have always wanted to do this.
good luck,
dj
