Spark Plug Problem
Old May 5, 2006 | 01:43 PM
pablocruz69's Avatar
pablocruz69
Spark Plug Problem
I changed all of my spark plugs and the wires a few weeks ago, the only one that did not get changed is the driver side rear plug. The problem that I am having is, I cannot get it out, I tried using the 5/8, 11/16, 3/4 spark plug socket but I cannot get it to come out. I am thinking that there may a trick to getting it out. Any help would be appreciated.
Old May 5, 2006 | 06:06 PM
wavinwayne's Avatar
wavinwayne
If it's a 4.6, there is no "trick". The plug is just a pain to get to. I did mine in Oct '05. It takes a regular old 5/8" spark plug socket.
If you've somehow managed to round off the flats on the plug, however, all bets are off.
Old May 5, 2006 | 08:59 PM
pablocruz69
If I use a mirror I can see the plug and the edges look fine, I think that there might be something that is not letting the socket seat properly. I am going to use a shop vac or some compressed air, and put it over the hole and hopefully get out something, like dirt??????? I am going to keep trying. Thanks for the reply.
Old May 6, 2006 | 08:57 AM
wavinwayne's Avatar
wavinwayne
Follow my conoluted thought process for a second:
What I would try is this; Attach the spark plug socket to a long extension, attached to a swivel, attached to another long extension, attached to a 1/2" to 3/8" reducer, attached to a 1/2" drive ratchet. That should get it out.
Old May 7, 2006 | 09:55 AM
pablocruz69
I am going to work on it today and I'll post reply if and when I get it out. Thanks for all the help and advise.
