oil pressure spec ?
Old May 5, 2006 | 04:26 AM
ford390gashog's Avatar
ford390gashog
oil pressure spec ?
when i start up my 03 5.4 i have 85-90 psi cold start at 1000 rpm it will then drop to 55-60 psi at hot idle but at speed 2,000-5,000 rpm the oil pressure will get as high as 120 psi. is this normal or a sign of problems? should the pressure get that high?i am using 5w20 chevron and a FL820s filter
Old May 5, 2006 | 02:58 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
In my '01 service manual, I couldn't find oil pressure specs for the SD's, but for the F150, the 4.6/5.4 for HOT pressure is 138-310 kPa (310kPa is basically 45lbs) @ 1500RPM.
Where did you tap the oil pressure? Before or after the filter?
Almost sounds like the bypass is stuck closed.
Old May 6, 2006 | 11:17 PM
ford390gashog
i found the issue , it was the sender summit sent the wrong ohm sender causing th egauge to read wrong so now its
80 cold start up 1100 rpm
35 hot idle
70-75 psi at 1500 rpm
Old May 7, 2006 | 10:20 AM
krewat's Avatar
krewat
35 is perfect!
jinxie
May 11, 2015 10:58 PM
jayc3169
Jun 2, 2014 08:38 PM
Rocky Mountain F150
May 20, 2014 10:31 PM
fordopie
Mar 29, 2012 09:08 AM
DT 466Man
Mar 12, 2005 07:58 PM
