Rotors
Old May 4, 2006 | 03:38 PM
bg9556's Avatar
bg9556
Question Rotors
Ok, everyone. What kind of front and rear brake rotors should I get for a 2000 Ford Explorer, 5.0?
Old May 4, 2006 | 06:27 PM
bg9556's Avatar
bg9556
Like what brand?
Old May 4, 2006 | 07:06 PM
srercrcr's Avatar
srercrcr
If you don't get Ford/Motorcraft you're risking squeal.
Old May 5, 2006 | 06:48 AM
marragtop's Avatar
marragtop
I you get cheap ones, I suggest you get them turned before installing.
Old May 7, 2006 | 11:39 PM
CobraXP's Avatar
CobraXP
Are you looking for regular rotors, slotted, slotted/drilled?
Old May 8, 2006 | 06:16 PM
dewyrussler's Avatar
dewyrussler
I, too am in need of rotors...except for a 99 4.0 sohc. From what I've been reading, you definitely get what you pay for. Does anyone have good/bad experiences with the premium raybestos?
Old May 9, 2006 | 02:03 PM
grease monkey's Avatar
grease monkey
If you can find a shop with a on car brake lathe it could save the head ache of the annoying sqeal.
The on car lathe cuts the rotor in the actual angle of the front end of the car which makes the cut perfect for the car. It is the best lathe I have ever used.
I have a buddy that is a mechanic for the City and he uses it on all the Cop cars.
http://www.procutinternational.com/h...hes/pfm90.html
Old May 10, 2006 | 04:17 PM
bg9556's Avatar
bg9556
Brake lathe
I have never even heard of that kind of brake lathe.....
Old May 10, 2006 | 05:53 PM
Betta's Avatar
Betta
I brought some other cheap kind of rotors for my 2001 EB within a month or so I was screaming everytime i hit the brakes. My best bet to go with Motorcraft or Ford OEM brand
Old May 18, 2006 | 07:24 AM
PWAXON's Avatar
PWAXON
I have always had good luck with Napa rotors and pads. Just put a set on my 02 Explorer, Squeak free.
