1 Ton Front Axle
Old May 3, 2006 | 09:23 PM
toolebox1's Avatar
toolebox1
1 Ton Front Axle
Now, On the 67 1 ton did the front axle stay the same as the 1960 or did they change to the twin I beam?
Or, What Year did the twin I beam start?
Old May 4, 2006 | 08:40 AM
51dueller's Avatar
51dueller
In 1967 the F-350 started using the twin-i-beam front suspension. 61-66 F-350 axles should fit your 1960 but it will still have 6 bolt wheels. You could try using a F-250 front axle. It should be as strong as the F-350 one. On the 48-52 the halftons and the ton trucks used the same front axle.
Old May 5, 2006 | 06:22 AM
toolebox1's Avatar
toolebox1
Thanks guys that is a great Idea !!!!!!
