Bronco II Ford Bronco II
90 B2: loss of power, high fuel consumption
Old 05-03-2006, 10:59 AM
gevalt65's Avatar
gevalt65
gevalt65 is offline
My 90 B2 Eddie Munster Edition is losing power and using an awful lot of gas even though I recently tuned it up. I removed the spark plugs and found that #1 and #5 were covered in what is probably unburnt fuel. I confirmed that spark was going to both plugs.
I'm thinking that the #1 and #5 injectors are stuck open (thereby causing the vehicle to bog under load), but was wondering if there's an alternate explanation that is more plausible.
Many thanks,
goldie.
Old 05-03-2006, 11:38 AM
ATVBronco's Avatar
ATVBronco
ATVBronco is offline
Take a look at the vacuum line on the fuel pressure reg. If it has fuel in it, replace the regulator. I had a similar problem last year on mine, was an easy fix. A bad reg will cause a rich condition.
Old 05-03-2006, 05:15 PM
my72ford's Avatar
my72ford
my72ford is offline
have you pulled the codes?
Old 05-04-2006, 07:42 AM
gevalt65's Avatar
gevalt65
gevalt65 is offline
No, I have not pulled the codes -- I'm not equipped to do that.
Also, why would a bum fuel pressure regulator affect only two of six cylinders?
Old 05-04-2006, 12:41 PM
mrshorty's Avatar
mrshorty
mrshorty is offline
You couldn't find a paper clip lying around, could you? A paper clip is enough equipment to pull codes, if you are willing to try. See Ken00's article in his tech info post.
"I'm thinking that the #1 and #5 injectors are stuck open (thereby causing the vehicle to bog under load)
If I suspected this, the first thing I might do is put a fuel pressure gauge on the fuel rail, pressurize the fuel system (ground fuel pump test lead), then turn the pump off, and see if the fuel system holds pressure. If the fuel system doesn't hold pressure, then you locate the "leak" (a stuck open injector is a possible cause of a leak).
mudinford
Modular V8 (4.6L, 5.4L)
38
12-26-2015 12:02 PM
lisagoud
10-01-2014 08:30 PM
G2IC_Wraith
1983 - 2012 Ranger & B-Series
17
09-30-2007 11:06 AM
B2WitDaBass
Aftermarket Products
01-25-2006 05:32 PM
Frost13
08-02-2004 07:06 AM
Quick Reply: 90 B2: loss of power, high fuel consumption
