clutch pedal return spring
Old Jun 18, 2002 | 02:36 PM
Mil1ion's Avatar
Mil1ion
Old Jun 19, 2002 | 05:48 AM
inliner's Avatar
inliner
Can someone tell me the measurements for the clutch pedal return spring that hooks to the dash and clutch pedal? Mine is missing and I need to get another one, it seems that it is neccessary to keep the clutch and brake pedal from rocking. I thought the play was the bushings so I changed them but the play is still there. I hooked up a spring I had lying around which helped but I don't think its strong enough. If you have one can you tell me the length when retracted and extended? Thanks.
