Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Much More Frame Swap
Old May 2, 2006 | 11:48 AM
51dueller's Avatar
51dueller
I decided to weld the frame myself. It took several hours and I have one side of body mounts on the frame. I'm working on some custom front cab mounts at the moment.
Next update a 6:00pm.
Old May 2, 2006 | 02:00 PM
Snowking's Avatar
Snowking
Looks straight from this angle. Good job
Old May 2, 2006 | 07:31 PM
51dueller's Avatar
51dueller
Here's some more pics:
These are the custom front cab mounts. They aren't the most beautiful thing in the world but they are solid.
I now have the stock pedals mounted. My master cylinder and booster are on their way from B.C which will be mounted behind the tranny crossmember.
Old May 2, 2006 | 07:44 PM
Corner Gas's Avatar
Corner Gas
Looks like you are doing a great job. By the time your done welding you won't have any problems welding anything.
Old May 2, 2006 | 09:46 PM
Dustin1690's Avatar
Dustin1690
You work fast good job and keep it up
Old May 2, 2006 | 11:02 PM
Fomoko1's Avatar
Fomoko1
Looking good, you`re moving along good. Looks quite similar to my 56 M100 cab/running board mounts.
Old May 3, 2006 | 12:28 AM
preppypyro's Avatar
preppypyro
Keep on with the welding, practice makes perfect
Old May 3, 2006 | 09:12 AM
51dueller's Avatar
51dueller
Well My Dad said the custom mounts weren't good enough so they have to be redone. I'm going to cut them out and make new pieces, then he can weld them in. He also wants to touch up a few welds where I joined the frame. Today I'm going to take the front suspension apart if it ever warms up! Dang snow.
Old May 3, 2006 | 06:07 PM
preppypyro's Avatar
preppypyro
Thats cool, sucks that it snowed yes, do you no thave a shop to drag it into?
Old May 3, 2006 | 07:38 PM
51dueller's Avatar
51dueller
I did turn it around to put the front end in the garage. I got the front suspension disassembled. Phoned Partsource and they couldn't get any bushings for the HD f-250 so I phoned the local Napa and they can get them all. I did slap some paint on the suspension crossmember.
Old May 3, 2006 | 08:18 PM
preppypyro's Avatar
preppypyro
Good old napa comes through again haha.
