mix and match
Old May 2, 2006 | 04:56 AM
Caddy 53's Avatar
Caddy 53
Angry mix and match
Fellow FTE Members : Am I correct in assuming that 53 thru 56 hoods will interchange. I realize that the 56 requires different hinge's but that's because of windshield - body difference. After looking for better hood for 53, I found a 56 hood. In a dream last night ,something told me maybe there some difference I wasn't awere of. I plan on using a tilt kit by NO LIMIT. I'm tired of fighting with hinges that eat paint.
thanks caddy 53 chuck
Old May 2, 2006 | 05:23 AM
merc546's Avatar
merc546
The hoods will interchange. The 56 hinge is different only because they changed the bolts to a larger dia shoulder. The 56 hood also has a small brace at the back which they attached with two small bolts. Mine was spot welded also, I just removed the bolts and welded the holes.
Good luck with the No Limit kit.
Chuck
'53 F100
Jan 20, 2014 12:37 PM
tempforce
Oct 28, 2013 01:15 PM
Aussie 53
23
Nov 28, 2007 07:35 PM
mtflat
Mar 27, 2002 01:21 PM
Caddy 53
User Gallery & Picture Display
Jan 22, 2002 10:17 PM
