Sponsored by: Auxito
lifting a bit higher
Old May 2, 2006 | 12:38 AM
ajm859830's Avatar
ajm859830
I have a 2wd 99 f150 with the fabtech 3.5" fabtech control arm lift and another 3" body lift (I think). Reason im not too sure about the body lift is bc I bought it used with no specs as to what was on it. Although along with the suspension lift which im 100% sure about it has 3" blocks all around and is sitting on 315/75R16 tires. Im looking to go alittle higher with it partictularly on the front being that it seems to have a slight slant to it. Do you guys think that I could be able to go with some 1.5" or 2.5" coil spacers to level it out and make it a bit higher?
Old May 3, 2006 | 03:21 PM
Mr. Man's Avatar
Mr. Man
I see no reason why you couldn't... just make sure and get it re-aligned afterwards... I'd sure like to see some pics of your truck, sounds like a sweet ride. btw, why not put some 37s on that thing? i'm sure you could fit em, lol.
Old May 3, 2006 | 10:17 PM
ajm859830's Avatar
ajm859830
Ill get you some pics tomorrow if youd like. If I could afford some 37's and knew theyd fit..Id go for it. New wheels are def. first on the list though ill be picking some up here in a few days and maybe the coil spacers if money is left over. The ones that it came with didnt have any center caps and are all dingy & scratched up and somewhat rusted in the spokes. Also I checked it out and it does have the 3" body lift on it.
