starter grind???
Old May 1, 2006 | 11:51 PM
79shovelhead's Avatar
79shovelhead
starter grind???
My starter on my 01 is starting to grind once in the while. Could this be the starter or flywheel. Is this common. Could one battery be getting weak be the cause? Just a thought
Old May 2, 2006 | 06:49 AM
Kwikkordead's Avatar
Kwikkordead
Only way to know for sure is to remove the starter and examine the ring gear.
Old May 3, 2006 | 12:44 AM
79shovelhead
Crawled under the truck today, found a loose starter bolt. So I called the tranny shop that just went through the tranny not 4 months ago. They said all bolts were tight. yeah right. I guess this weekend project will be inspect the flywheel. I know I will be the guy pulling the trans this time.
