How do I remove the fuel pump
Old May 1, 2006 | 08:06 PM
thedettras's Avatar
thedettras
I need to replace the fuel pump in my '83 F-100 3.8L v-6. The bolt towards the front of the engine I can reach without any problem. But I cannot figure out how to get at the bolt towards the rear of the engine. Any suggestions.
Old May 17, 2006 | 11:42 PM
peterbiltford's Avatar
peterbiltford
the fuel pump is located on the drivers side front on the engine, its above the oil filter and there are only 2 bolts which are verticaly aligned, and then your half inch gas line and your intake rubber line. the two bolts are half inch and once you get the bottom loose take out the top all the way and the pump should move out
