Airconditioner
Old May 1, 2006 | 05:55 PM
bmxerbrett's Avatar
bmxerbrett
Airconditioner
I have an 87 150 5.0 It is retrofitted to 134. My prob is the compresser cycles on and off very fast. I unpluged the cycle switch from the dryer and connected the two leads together. The compressor stays on when I do that and the a/c line gets frost on it up to a certian point. Somebody told me it is a orfice tube. I tried taking it apart but I can't figure out how to take that damn tube apart. If I just take it somewhere is this a cheap fix? Please help. I live in Texas and it's HOT! Thank you.
Brett
Old May 1, 2006 | 06:03 PM
mhg's Avatar
mhg
you need to put a set of gauges on it
your symtoms are low on freon
check for leaks
Old May 2, 2006 | 07:32 AM
bmxerbrett's Avatar
bmxerbrett
check for leaks
It wont take anymore freon. There is a clog. I just need to know how to take out the orfice valve.
Old May 2, 2006 | 10:07 AM
gatesj's Avatar
gatesj
Air conditioner forum will have more information:
http://www.autoacforum.com/
You need a vacuum pump and a set of manifold gauges at least to do it right. Otherwise it will fail in short order again and be even more expensive.
Old May 2, 2006 | 05:30 PM
bohiaa's Avatar
bohiaa
The orfice Is less of the issue....Sounds like you have a restriction.
gatesj is right...........
