stereo removal
Old May 1, 2006 | 05:20 PM
cumminpwr11's Avatar
cumminpwr11
stereo removal
quick and easy.
Anyone know where and how much the key or tool is to remove the factory stereo?
OR is there a way to get it out with out them?
Chris
Old May 1, 2006 | 05:28 PM
NC Medic's Avatar
NC Medic
I have used Small Allen Wrench before it worked great
Old May 2, 2006 | 02:01 AM
ramsmoker's Avatar
ramsmoker
Talking steroe removal
3/32 brass rod or 4 little pocket screw drivers.
Old May 2, 2006 | 10:29 AM
hink10's Avatar
hink10
Originally Posted by cumminpwr11
quick and easy.
Chris
You can use a hanger or other similar object, but I would buy the tool. If you mess up the clips, you have to pull the dash. You can pick up the tool for less than $5 a parts stores.
Old May 2, 2006 | 10:36 AM
cgl's Avatar
cgl
The tool set is 3.99 at wal-mart. They have a little groove on the end so they'll work properly with the locking mechanism. Just push in untill it clicks (you won't get a click using a coat hanger), push the tools away from each other and pull out.
The coat hanger trick does work, as does the screwdriver idea. Just knowing when to stop inserting is the key. If you go in to far it won't work.
Old Feb 20, 2010 | 10:35 PM
X-Hibition's Avatar
X-Hibition
So how far is too far? I have two sets of the removal tools and have tried both, going in a little bit or going in a lot. I hear noises and feel something but the head unit won't come out.
What is the magic length that I need to employ when I stick my tool in the hole?
Easy now.
I'm trying to get out of town with the new PIE installed.
Old Feb 21, 2010 | 12:36 PM
X-Hibition's Avatar
X-Hibition
No stereo removal gurus out there?
No love?
Old Feb 21, 2010 | 12:57 PM
hink10's Avatar
hink10
No love?
I'm no stereo removal guru, in fact I have one I can't get out because the clips that hold it in place are damaged on one side. I have tried the removal tool however, You want to push them in slowly, you will hear and feel the click when the tool engages the clips, don't need to go in too far. If you get the tool to engage in the proper place on each side, gently apply pressure towards the outside of each side and at the same time wiggle/pull the head unit free. It may take some patience, hopefully the clips aren't damaged. I could only get one side on mine free. I hope that helps and makes some sense.
Steve
Old Feb 21, 2010 | 01:01 PM
X-Hibition's Avatar
X-Hibition
Thanks for the assist Steve, but how far is too far? Or how much is enough? I'm looking for a measurement because I can hear all kinds of noises and want to make this happen.
And the sun is out...
Old Feb 21, 2010 | 01:09 PM
hink10's Avatar
hink10
I'm not sure I can give you an exact distance but it's not far. If you get a flashlight and look in the holes, you can see where the tool will enter. It only needs to go in a short distance after that. Don't go in too far. If the clips are even slightly damaged, it can be a real pain and the more you mess with it, the greater chance the clips will be damaged. You might try running by a Best Buy or other installation shop and see if they can get it out quick? Sorry I can't be of more help, good luck! I feel your pain, I spent a long time trying to get mine out and never did.
Old Feb 21, 2010 | 02:09 PM
Reticle's Avatar
Reticle
The tool should engage the clip exactly 1.25" from where it enters the hole in the faceplate. You will need to go maybe .125" at most past that point depending on if the tool has the little notches on the end.
Old Feb 21, 2010 | 02:13 PM
X-Hibition's Avatar
X-Hibition
Now that is an answer.
I know I went way past that before.
Excuse me while I run outside.
Thanks.
Old Feb 21, 2010 | 02:20 PM
Reticle's Avatar
Reticle
Yea, it can be tricky because when you go in too far the tool won't allow the clip to fully depress.
Old Feb 21, 2010 | 02:31 PM
X-Hibition's Avatar
X-Hibition
Hey Reticle,
You are my hero. Beers are on me when you get to town.
I don't mean kinda, or even sorta, I measured off 1.25" on the removal tools, stuck them in and it popped right out. Wheeeeeeeeeeeeeeeee.
Back to the PIE install.
Thank you.
Old Feb 21, 2010 | 02:33 PM
Reticle's Avatar
Reticle
No problemo.
